shaunak1 Reputable Mar 11, 2015 32 0 4,530 Mar 12, 2015 #1 Hello friends, Can I go to buy wd blue 1tb wd10ezex hard drive. It has sata 6gb/s but my motherboard is DH61WW it has sata 3gb/s port, can i run this hard drive ! I Also Want To Know That How Much Read And Write Speed I will get.
Turb0Yoda Expert Ambassador Jul 12, 2013 4,876 9 23,465 Mar 12, 2015 Solution #2 Yes you can, but the read/write will max out at 3 GB/S Upvote 0 Downvote Solution
shaunak1 Reputable Mar 11, 2015 32 0 4,530 Mar 12, 2015 #3 thanks for that, I bought Corsair VS550 is that sufficient ? Upvote 0 Downvote
Turb0Yoda Expert Ambassador Jul 12, 2013 4,876 9 23,465 Mar 12, 2015 #4 What is the rest of your Hardware? The lower end Corsair PSU's(CS,CSM,CX,VS) don't use good caps, and are only good for light office use... Upvote 0 Downvote
ko888 Titan Feb 18, 2009 16,706 42 84,990 Mar 12, 2015 #5 Yes SATA 6 Gb/s HDDs are backward compatible with SATA 3 Gb/s SATA ports. The Western Digital WD Blue WD10EZEX doesn't even come close to saturating a SATA 3 Gb/s bus. You can see what type of performance users are getting from that specific model here: http://hdd.userbenchmark.com/WD-Blue-1TB-2012/Rating/1779 Upvote 0 Downvote
shaunak1 Reputable Mar 11, 2015 32 0 4,530 Mar 12, 2015 #6 Intel i3-2100, Intel DH61WW mobo, Nvidia Geforce gtx 660 graphics, 8gb Ram, 1 Cd-rom & Wd blue 1tb wd10ezex hard drive. so that's it ! Upvote 0 Downvote
Turb0Yoda Expert Ambassador Jul 12, 2013 4,876 9 23,465 Mar 12, 2015 #7 You should be fine with the PSU you have. Upvote 0 Downvote
