The primary benefit of playing Fortnite Battle Royale is that the players get to create structures according to their creativity. One of those structures is the Panic Ramp.
It can be a very useful structure if you want are about to engage in a battle. Take a look below for complete guide about the Panic Ramp:
Why You Need it?
A panic ramp is a great way to save yourself from an enemy who has a stronger weapon and not only that; it will give you a height advantage that will help you maintain pressure over the enemy. And not just the advantage of height, it will also help you get cover if you are getting returning fire. You can just dip into the ramp to get cover. The walls surrounding your ramp will save you from the incoming fire even if you are at an open area. This is the primary reason that players create panic ramps as it not only saves them from imminent death, but it also gives them an upper hand over the enemy.
When to Use it?
The ideal time of using a panic ramp is when you have spotted an enemy at a distance and he is coming right at you. You can then make quick preparations to welcome them through your panic ramp. Secondly, you can also use it if you are in a fight. You can quickly throw some walls and a ramp and get on it to start shooting on the enemy below. The time it will take your enemy to shoot down the walls surrounding your ramp, you can take him out in that time.
How to Use It?
It is pretty easy to use a panic ramp. Once you have successfully created one, you need to go to the upper edge of the ramp and then peak over the edge to see the position of your enemies and then open fire at them. Once you start to get fire in return, you can always dip yourself into the walls surrounding the ramp to save yourself from the enemy shots. It is a simple and effective way to fight in tough situations.
How Build It?
It is really simple to build a panic ramp. You just need to put some wooden walls in a way that creates a square wooden box. Just make sure that you remain in the center of that box. Once the box is in place, put a ramp in the center leading upwards. If you have not placed the wall behind the ramp, then place it before you start engaging with enemies to save yourself from every side.
It is very easy and effective structure that can be created in seconds. During your battle, you can take help from a panic ramp and quickly get a cover and an advantage of height over the enemy.
Just remember that it is easy to destroy the ramp if one has a launcher or minigun, so do not think of it as a permanent solution.
Why You Need it?
When to Use it?
How to Use It?
How Build It?
