How to set up Audio Technica ATR-2100 Microphone
techguy11
24
Step 1
Plug in the microphone, don't connect your monitoring headphones yet as it can cause problems with driver installation.
Step 2
Next Windows will install the drivers, again make sure you haven't plugged in your monitoring headphones as it can cause issues with this process.
Step 3
Now you may plug in your monitoring headphones if you wish.
Step 4
Now you will have to configure your computer to use the microphone, although generally it's good to check just in case. So click Start, Control Panel, if your using the old format (Icons) click on Sound but if your using the new format (Categories) click Hardware and Sound, Sound. This should bring you to this window.
Make sure that the default speaker and recording device is set to the ATR Microphone. If it is not, click on the ATR Microphone and click Set Default. You can also double click on it and click Levels and set the volume to 100% from the default 25% which is too quiet.
Step 5
Enjoy your microphone, if sound is not being outputted by a certain program then check that program's settings and make sure that the speakers and microphone are set to ATR Microphone. Some programs that may do this include Skype and Fraps.
