First time building a PC so looking for advice on any changes that would be recommended.
Primary use will be Modelling and Rendering in 3DsMax and V-ray, with some photography editing in Photoshop.
Budget is £800-£900 but can got to around £1k if it's going to be really worth it.
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor (£248.98 @ CCL Computers)
CPU Cooler: Cooler Master Hyper TX3 54.8 CFM Sleeve Bearing CPU Cooler
Motherboard: Gigabyte GA-Z170N-Gaming 5 Mini ITX LGA1151 Motherboard (£125.89 @ Dabs)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory (£72.90 @ More Computers)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive (£56.03 @ Amazon UK)
Video Card: EVGA GeForce GTX 750 Ti 2GB Superclocked Video Card (£94.99 @ Novatech)
Case: Corsair 380T Mini ITX Tower Case (£97.98 @ Amazon UK)
Power Supply: EVGA SuperNOVA GS 550W 80+ Gold Certified Fully-Modular ATX Power Supply (£64.99 @ Aria PC)
Total: £761.76
Generated by PCPartPicker 2015-12-21 15:20 GMT+0000
NOTES
I went ITX because I really like the case and it will be sitting on top of my desk.
Didn't go for 6700K as I have no clue about overclocking.
PSU, no clue about this either. Done a couple online calculations and picked a higher rating. This is the component im most worried about.
GPU. Vray is a CPU renderer so I'm not sure if this card is overkill or if there is visible difference with a cheaper card.
Will be using old hard drives from laptops. But thinking about getting a 1or2TB since they're pretty cheap these days.
Total: £761.76
NOTES
