Hi, it is time I build myself a new computer. I'll be using it for everything, from gaming to video editing and web developing. I gathered a list of parts that are good in my opinion but not completely sure. Please share your thoughts and give me some suggestions!
COOLER MASTER HAF 932 Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160
[strike]Intel Core i7 920 Nehalem 2.66GHz[/strike] *BOUGHT*
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
Spire Thermax II Heatsink <<< ?????? 😱
http://www.frostytech.com/articleview.cfm?articleid=2348&page=2
[strike]ASUS P6T Deluxe LGA 1366 Intel X58 ATX Intel Motherboard[/strike] *BOUGHT*
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131346
MSI N285GTX-T2D1G-OC GeForce GTX 285 1GB 512-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127403
OCZ Reaper HPC 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 15000) Triple Channel Kit Desktop Memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227379
CORSAIR CMPSU-850TX 850W ATX12V 2.2 / EPS12V 2.91 SLI Ready CrossFire Ready Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139009
2x (Raid 0) Western Digital Caviar Black WD1001FALS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136284
OCZ Solid Series OCZSSD2-1SLD60G 2.5" 60GB SATA II Solid State Disk (SSD) FOR WINDOWS
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227373
LG Black 22X (CAV) DVD+R 8X DVD+RW 16X DVD+R DL 22X (CAV) DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 22X DVD±R DVD Burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136152
LITE-ON Black 18X DVD-ROM 48X CD-ROM SATA DVD-ROM Drive Model iHDS118-04
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106276
So there it is, everything comes out to $1,877.90 (heatsink not included). But I wont be buying all the parts from newegg, so total should come out less... I need you guys to help me pick out a good heatsink for the CPU. I will want to overclock the CPU to at least 3.6GHz. I was looking on FrostyTech.com , they made up a list for TOP 5 Intel heatsinks and Spire Thermax II heatsink is in #3 spot. I haven't seen many people talk about this heatsink, but frostytech seems like a reliable source. I'd like to know what you guys think, maybe this heatsink isn't that good and you can suggest me a better one.
Also, I've read that SSD drives have some data corruption and random pauses issues. Can anyone suggest me something other than SSD with similar speeds?
I might just get this instead Western Digital VelociRaptor WD1500HLFS 150GB 10000 RPM 16MB Cache SATA 3.0Gb/s Hard Drive http://www.newegg.com/Product/Product.aspx?Item=N82E16822136296
I already bought the i7 920 CPU with P6T Deluxe mother board.
Thanks in advance
Thanks in advance
