¿Should I pick GTX 1060 or RX 580? (in terms of power consumption)
WaDePeDritou
7
Hey guys, i'm new here and i'll build a pc for some gaming (from LoL and DotA2, to some GTA 5 and Battlefield, Asetto Corsa, Playerunkown BG, and so on), 3Dmax, Autocad, Cinema 4D, and some Adobe software, but i keep making myself the same question....
Which GPU of both options (1060 or 580) to pick, having in mind power consumption?
The build is:
CASE: NZXT S340 Midi-Tower
MoBo: Gigabyte ATX GA-AX370-GAMING K7
CPU: AMD Ryzen 5 1600
GPU: ¿?¿?¿?¿?¿?¿?¿¿?¿?¿?¿?¿?¿?¿¿?¿?¿?¿?¿?¿?¿¿?¿?¿?¿?¿?¿?¿
RAM: Kingston HyperX FURY Black DDR4, 2133MHz 8GB
SSD: Lite-On MU3 PH5, 120GB, SATA III, 2.5"
HDD: Toshiba DT01ACA100 3.5'', 1TB, SATA III, 6 Gbit/s, 7200RPM
COOLER: CPU Cooler Master Hyper 212 EVO
EXTRA FANS (x2): Cougar CF-D12HB-R, 120mm, 1200RPM (Front of the case)
PSU: 500w Corsair - TXM Gold 550W 80+ Gold Certified Semi-Modular
WLAN CARD: PCI Express Double band AC1200
SCREEN: LG 29UM58 LED 29'', Full HD, UltraWide, HDMI
MOUSE: Logitech G502
KEYBOARD: ---Still thinking about which one---
I'm aiming to stay with this build at least 5-6 years (maybe adding more ram from time to time)... But what really worries me is the amount of difference in power consumption, i wanna know (if someone has either cards) if that factor is really a big deal when refering to "electricity bill".
I mean, if the diference is not that big (like 10% more power usage between gtx 1060 and 580 per month) i'll definitely go for AMD, but if its really a big problem i'll pick the gtx 1060
rx 480? i dont like it that much... FYI, i'm planning to use my pc like 6-7 hours, 4 to 5 days a week
PS: yeah, i know about free-sync and v-sync and g-sync + long term value + longer support over years with AMD + heat+ noise + MSI or GB or EVGA editions + bla bla bla... what really keeps me worried is power usage in terms of money i'll pay on bills over the years
Is there a specific link to this build? If so please send me the link.
The RX 580 won't impact your electric bill , same as a GTX 1060. They are both very power efficient.
Once again send me the link or your price range/ currency. The build can use some fixing in terms of price/perf.
you mean this....? (couldn't find the same SSD)
https://pcpartpicker.com/list/wtgbHN
CPU: AMD - Ryzen 7 1700 3.0GHz 8-Core Processor ($299.44 @ OutletPC)
Motherboard: MSI - B350 TOMAHAWK ATX AM4 Motherboard ($101.98 @ Newegg)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory ($112.99 @ Newegg)
Storage: PNY - CS1311 120GB 2.5" Solid State Drive ($52.99 @ Best Buy)
Storage: Toshiba - 1TB 3.5" 7200RPM Internal Hard Drive ($45.89 @ OutletPC)
Case: Corsair - SPEC-03 Red ATX Mid Tower Case ($37.98 @ Newegg)
Power Supply: Corsair - CXM 750W 80+ Bronze Certified Semi-Modular ATX Power Supply ($54.99 @ Newegg)
Monitor: LG - 29UM58-P 29.0" 2560x1080 75Hz Monitor ($252.28 @ Amazon)
Total: $958.54
Generated by PCPartPicker 2017-06-12 19:26 EDT-0400
*I Tweaked Sometings! Youre getting super better performance. The Ryzen 7 1700 comes with the Wraith Spire RGB Cooler too! The fans and cooler are not needed...
Purchase Windows Here:
https://www.kinguin.net/category/19429/windows-10-professional-oem-key/
That's the bad CX 750M. And promoting kinguin or G2A or CDKeys for Windows 10 is a gray area in both legality and on this forum. Be aware of promoting them.
Thnx for the advice, anyway i wasn't considering buying wiindows 10 so fast, i'll check other options...as for the PSU i picked the 500w Corsair because it has 7 year warranty
I forgot to mention i live in Mexico so 958 dollars for me is like almost triple considering my currency in this times
anyway, is there any diference between B350 Tomahawk, and B350 Gigabyte gaming 3?
Not really a difference between the two motherboards.
I suggest the RX 580, it's a bit better and has 1 more GB of VRAM if you go for the weaker one.
The electricity bill is same for both, in 10 hours of gaming they're going to waste around 1.5KW.
I see you chose the Corsair TXM. Those are indeed pretty good units, even without the 7 year warranty. I was just pointing out to that Subaru guy for choosing that CX unit since it is a bad unit.
no, get the cheaper one
also the ryzen 1700 is NOT worth it over the 1600
also +1 on the rx 580
The 1700 won't make a difference in gaming, games will not utilize all cores even on the 6 core.
You're right, but no need for 750W anyways.
Well, OP said he's going to use Premiere, AutoCAD, and 3ds Max. But yep, OP doesn't have the budget to get a R7-1700 anyways.
