If you have not already tried it unplug and replug the lan cable.
You can also so IPCONFIG /release and then IPCONFIG /renew.
This should force it to ask the router for a new IP. Generally this type of error means the physical cable is good but you are not getting a IP from the router. If there are other devices like a switch or powerline device in between those could also cause this.
