0.75v Memory voltage too low?
eli_singer
35
i had a problem with my PSU where my 3.3v channel was getting below 3v.
i changed it to a new Seasonic X-650w and it fixed the problem, but, i noticed that the Memory voltage is running very low on 0.75v and that was the case with the old PSU and with the new one.
this is how it looks:
is that normal? should i check something?
my rig is:
MB: Intel DZ77RE-75K
CPU: i7 3770K
RAM: X2 G.Skill 8gb F3-10666CL9
GPU: MSI GTX 660
PSU: Seasonic X-650w
Thanks,
Eli
That's definitely an inaccurate reading. Memory voltage is provided by the VRM on the motherboard, not the power supply itself. If it was truly 0.75 volts, your computer would not be running. See if there are any firmware updates available for your motherboard.
