Question 0db fan not acessible?
Nowheredude
Commendable
Feb 4, 2021
I just got a new gpu, Rtx 3060TI Colorful igame, and in the official colorful website, they say that this model has the 0db feature (they call it auto stop technology). But when I go to Msi afterburner to create my fan curve, the 0% option is not available, there’s a libe on 30% saying that my gpu can’t go lower then that. I have no idea what’s stopping me from using it, does anybody had the same problem with colorful cards?
The 0DB mode should be at idle or basically not loading the card to a temperature point where the fan needs to cool the card.
Reactions: Nowheredude
There's an option called "Override zero fan speed with hardware curve", though it's also possible MSI Afterburner (or any other utility since they hook into the same places) can force the fans to turn off.
Thank you so much, it really worked. Just don’t know why I needed this option if colorful says my card support it natively
But the software don’t allow me to go under 30% fan speed( even if it says in the colorful site that the gpu supports this feature),that’s the problem. I managed to force through the msi afterburner, just don’t know why I have to force it in the first place
