$1,000 Dollar Build (Edits, Help, Suggestions)
robosodope
45
I have made a $1,000 build and hoping to run 60+ fps on new 2015 games. If anyone can review it, tell me if it is ok, or edit it that would be awesome!
CPU
Intel Core i5-4690K 3.5GHz Quad-Core Processor
Motherboard
Gigabyte GA-Z97X-SLI ATX LGA1150 Motherboard
Memory
G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory
Storage
Samsung 840 Pro Series 128GB 2.5" Solid State Drive
Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Video Card
Gigabyte GeForce GTX 970 4GB WINDFORCE Video Card
Case
Corsair 200R ATX Mid Tower Case
Power Supply
SeaSonic 620W 80+ Bronze Certified Fully-Modular ATX Power Supply
Optical Drive
Samsung SH-224DB/BEBE DVD/CD Writer
Operating System
Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)
Monitor
Acer H236HLbid 60Hz 23.0" Monitor
Great build.your build is basically the same as mine. i would suggest you get a deacent cooling system, prefferbly watercooling as you overclocking you CPU if you arnt then not nessasary but then get a diffrent CPU.. for your SSD try the 850 pro 128gb or the 250gb evo both really good. For ram kingston is good quality and you could upgrade to a 1866GHz or a 2400GHz it will just be nice see that you have a nice budge. heres another sexy tower.
Corsair Carbide SPEC-03, Midi Tower, Windowed, Black, ATX
hope it helped
If you don't want to overclock, just get yourself an i5 4690 and use the extra money on a case with better features. The 200R is a very aesthetically pleasing case, but some of the features are lacking (cable management, sound dampening).
Otherwise, the build looks great!
Woody
