Putting together a new desktop for a family member. Building to last as along as possible - may one day be re-purposed to an older gaming machine. I like the idea of sticking with NVIDIA for the gfx card as CUDA is/could be useful given the nature of the box. This will be a home drafting box, so no need for Quadro, etc.
Do all these parts jive together? Any better options?
Would it be worth looking into SSD caching and a smaller HDD?
Approximate Purchase Date: Next two weeks
Budget Range: $1,000
System Usage from Most to Least Important: 2D (maybe some 3D in the future CAD drafting, MS Office, browsing, maybe one day for gaming)
Are you buying a monitor: No
Do you need to buy OS: Yes
Overclocking: No
SLI or Crossfire: Not immediately, maybe in the future
On to the parts....
CPU: Intel Core i5-3470 Ivy Bridge 3.2GHz (3.6GHz Turbo Boost) LGA 1155 77W Quad-Core ($200 @ Newegg)
Motherboard: ASRock H77 Pro4/MVP LGA 1155 Intel H77 HDMI SATA 6Gb/s USB 3.0 ATX ($120 @ Newegg)
CPU Cooler: COOLER MASTER Hyper 212 EVO RR-212E-20PK-R2 Continuous Direct Contact 120mm Sleeve CPU Cooler ($35 @ Newegg)
Memory: 2x CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Profile Desktop (16GB total) ($80 @ Newegg)
Storage: Western Digital WD Blue WD10EALX 1TB 7200 RPM 32MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive ($100 @ Newegg)
Video: EVGA SuperClocked 02G-P4-2662-KR GeForce GTX 660 2GB 192-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI ($225 @ Newegg)
Optical: LITE-ON DVD Burner ($20 @ Newegg)
Power Supply: CORSAIR Builder Series CX600 600W ATX12V v2.3 80 PLUS BRONZE Certified Active PFC Power Supply ($75 @ Newegg)
Case: Corsair Carbide Series 200R Black Steel structure with molded ABS plastic accent pieces ATX Mid Tower ($70 @ Newegg)
OS: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit) ($100 @ Newegg)
Total: $1,025
Thank you!
Overclocking: No
On to the parts....
Total: $1,025
Thank you!
