Hey guys and gals. I am in the market to replace my very old monitor. Currently running 1360*768 @ 720 P
I am looking for a 1920*1080 resolution.
I am considering 1440p monitor
My set up is a typical i3 6100 paired with a rx480. I am mostly into multiplayer games.
I am leaning towards a 1080 P setup so I can run ultra settings in most games. I am considering buying two 1080p monitors. I believe the 480 will handle this with minor hiccups and a few adjustments to settings.
I have read and seen that a Rx 480 is able to run 1440p. However graphics have to be adjusted. If it can't run on ultra on one monitor, I Highly doubt it could run two 1440p monitors on low or med settings. I am not an ultra settings fan boy. It just makes sense that what I purchase I can utilize to it's full potential.
I've read that two rx480s running simultaneously have hiccups with 1440p on ultra settings on a single monitor in some demanding titles.
Questions
What is a better experience 1080 P at ultra settings? Or 1440p at med -high settings?
If I go the 1080 route I will most likely buy two monitors.
If I go the 1440 P route I will buy one initially. I may stick with one seeing as an Rx 480 may already be stressed.
The 1080 monitors I am considering are
https://m.newegg.ca/product/index?itemnumber=N82E16824116778
Has 1080, 2ms response time, freesync, display port, TN
https://m.newegg.ca/product/index?itemnumber=0JC-000D-004W2
1080, 5ms response time, freesync, no display port, ips
Can anyone recommend a better monitor? Or pros and cons. Other than aformentioned. Is freesync really a huge bonus? Or should I look into a plain IPS monitor with lower response time? Is 2ms on the tn really that much better than 5 Ms on the IPS! Is display port a noticable difference from HDMI?
As for the 1440p monitors I am looking at the Korean crossover brand. Unless someone suggest other.
Thank you kindly.
Questions
Thank you kindly.
