So overclocking is defiantly a finicky bitch. 4.4ghz stable with a +.025V offset and .012V turbo and LLC off (level 5 on my asrock z77 extreme4, least compensation)
I tried to go to x45 but i was getting a ton of WHEA errors, temps near 90C (volts were upped to like .040V offset and a .012V turbo and i couldn't get it stable. and was afraid to go higher on volts.
so i went back to 44x and tested prime. was stable
wanted to try again so i reconfigured the memory timings and frequency and now im stable? also got LLC on level 2 but i tried that before and it still was unstable. So the only real thing i changed was the memory.
I went from 1600MHz 9/9/9/24 1CR // 2CR (tried both)
to 1300MHZ 11/11/11/28 2CR
and LLC to level 2 to reduce droop.
..but my temps are lower. Can looser memory timings cause a more stable overclock and lower temps?
1.320 V on i5 3570k for 4.5ghz normal?
because i see a ton of reports people doing much lower for 4.5ghz
build = i5 3570K
asrock z77 extreme 4
g.skill ripjaws x
build = i5 3570K
g.skill ripjaws x
