1.4GHz PIII-S Tualatins on a VP6!! HELP!!!
G
Guest
Guest
Archived from groups: alt.comp.hardware.overclocking,alt.comp.mainboards.abit,alt.comp.periphs.mainboard.abit (More info?)
Hello --
I don't normally cross-post, but in this case I'm quite desperate for help
(please see sig for spec). I have recently purchased two Tualatin Pentium
III-S, 1.4GHz 512KB L2 cache. In order to get these to work with the VP6, I
also purchased two Lin-Lin S370 adapters.
After installing everything according to instructions, I have found that the VP6
will only boot reliably with one of these processor/adapter combinations
installed. It seems to run reliably at default speed (133MHz x 10.5) - it's
been running SETI for about two hours now and hasn't crashed.
Does anyone know how to get the VP6 to boot with *both* of these
processors/adapters installed? My VP6 has been flashed to the latest "DR"
BIOS, and has the capacitors replaced (thanks Big Badger!!).
Is it a matter of supply more power to the CPU sockets? Or is there a problem
with the VP6/Lin-Lin combination?
I will be very grateful indeed for any help I receive. Best regards,
Rohan Beckles
rohan.beckles@virgin.net
ABIT VP6
Intel "Tualatin" PIII-S 1.4GHz (1 off)
1GB SDRAM
Seagate Barracuda II 20.4GB
ABIT Siluro Ti4200 OTES 128MB
Hi Rohan,
Have you heard of anyone successfully running such a set-up? I could not
find a compatibility list for the Lin-Lin adapter but Upgradeware have one
for their very similar 370GU adapter, here:
http://www.upgradeware.com/english/product/370gu/compatibility.htm
Although the 370GU does normally support dual processors the compatibility
list specifically states VP6 support in single cpu mode only. I really can't
figure out why this should be because other similar, Via chipset, dual PIII
boards are listed with dual support.... But it makes you wonder if there is
perhaps something about the VP6 that prevents dual Tualatin support, even
with adapters?
*****Replace 'NOSPAM' with 'btinternet' in the reply address*****
"Rohan Beckles" <rohan.beckles@virgin.net> wrote in message
news:40ded2d5$0$288$cc9e4d1f@news-text.dial.pipex.com...
> Hello --
I
the VP6
it's
problem
> Rohan Beckles
> ABIT VP6
> 1GB SDRAM
BigBadger wrote:
> Hi Rohan,
> with adapters?
It might well be something to do with the VP6. For a moment I thought that it
might be that the Lin-Lin adapter was wired up to act like a Tualatin Celeron,
i.e. no SMP capability at all, since it is labelled as a Tualatin Celeron
adapter. However that would be kind of silly.
My only other alternative seems to be the Powerleap PL-370/T (£35.00 each), or
better yet getting hold of an IWill DVD266-Rn motherboard, which would mean
investing in DDR-SDRAM.
Do you know if other companies such as ASUS do such adapters at reasonable
prices?
Best,
ABIT VP6
1GB SDRAM
Rohan Beckles <rohan.beckles@virgin.net> wrote in
news:40def7c6$0$284$cc9e4d1f@news-text.dial.pipex.com:
> BigBadger wrote:
>> Hi Rohan,
> not
> e one
> ility
> y can't
> l PIII
> ere is
> even
>> with adapters?
> that it might be that the Lin-Lin adapter was wired up to act like a
> Tualatin Celeron, i.e. no SMP capability at all, since it is labelled
> as a Tualatin Celeron adapter. However that would be kind of silly.
> each), or better yet getting hold of an IWill DVD266-Rn motherboard,
> which would mean investing in DDR-SDRAM.
> reasonable prices?
> Best,
I don't know of any other adapters than those already mentioned. I've
got a brand new Supermicro 370DDE here if your interested. It uses the
Via 266pro chipset but still uses 'single data rate' ram. It's not
Tualatin ready though, so you would need to use the adapters.
Brand new? I thought that Supermicro EOL'd that board long ago - looks like I
was wrong. How much would you let it go for? Is there any chance of you
testing it with Tualatin adapters to make sure it's compatible? Also, what are
its overclocking capabilities?
BTW, I just looked the the next one up from that board, the P3TDDE. Using the
VIA Apollo Pro 266T chipset, it supports the Tualatin processor out of the box,
yet still only uses single data rate SDRAM. Isn't that odd, considering the
266/266T is supposed to be a DDR chipset?
Best,
"No greater love hath a man, than he lay down his
life for his brother.  Not for millions.  Not for
glory, not for fame - but for one person...in the
dark...where no one will ever know, or see..."
- Sebastian, "Comes the Inquisitor", Babylon 5
news:40df1201$0$286$cc9e4d1f@news-text.dial.pipex.com:
> looks like I was wrong. How much would you let it go for? Is there
> any chance of you testing it with Tualatin adapters to make sure it's
> compatible? Also, what are its overclocking capabilities?
> Using the VIA Apollo Pro 266T chipset, it supports the Tualatin
> processor out of the box, yet still only uses single data rate SDRAM.
> Isn't that odd, considering the 266/266T is supposed to be a DDR
> chipset?
> Best,
Rohan; check your email
Rohan Beckles wrote:
> BigBadger wrote:
>>Hi Rohan,
>>with adapters?
It could well be Lin-Lin used the "wrong" pin for the BR1# CPU bus
request signal.
I had the same problem when trying to run dual PIII-S processors on the
Asus P2B-DS using Upgradeware Slot-T adapters - the board would POST
with one processor but not two. The adapters originally used pin X2 for
BR1#, which is correct according to Intel documentation, but they did
not work until I modified them to use pin N33 - which is "reserved"
according to Intel but used for BR1# on some Powerleap adapters. More
details here:
http://tipperlinne.com/slot-t.htm
HTH
P2B
> prices?
> Best,
> request signal.
> details here:
> HTH
> P2B
This sound plausible but would it actually prevent the system from
POST'ing???? I would have expected that if that was the problem the PC would
POST with two CPU's installed but only show single CPU mode.
>>> request signal.
>>> details here:
>>> HTH
>>> P2B
Before the mod it would only POST with one CPU in the rear slot. Move
the CPU to the front slot, or add the second one, and it would just sit
there with fans spinning - no video or beeps, and no BIOS activity on a
POST diagnostic card.
I never did figure out why. Powerleap's PL-P3/SMP adapters have a jumper
to select X2 or N33 for BR1#, and both settings work in dual mode on the
P2B-DS. Asus S370-DL adapters use X2, and they also work (with Tualatin
pin mods), but the Slot-T only works using N33. Beats me 🙂
P2B
I have tested several VP6's with 3 different brands of "Tulatin" adapters.....
So far the results have been the same.......BAD
The VP6 runs better with coppermine based CPU's
Gary
Mainboards, Videocards & CPU pin repair.
http://motherboardrepair.com
gary@motherboardrepair.com
Hello --
Rohan Beckles
ABIT VP6
1GB SDRAM
Archived from groups: alt.comp.hardware.overclocking (More info?)
Yes, IMHo is better to get a genuine 2Cpu Tuallie MoBo (maybe some
Supermicro one somewhere) than to loose time trying to make it work
with VP6
Maybe also to lay hands on a used Epox ep-d3va board (2x s.370, Via
chipset) & try with his existing adapters his 2 Tuallies if they work
properly on that MoBo.
the next option would be getting from eBay some duallie Asus P2B MoBo
(BX chipset Slot1) & 2 slotkets (MSI v.2xx & mod them for Tuallies) or
get 2 Slot-T slotkets & follow the mod on them on the P2B´s site :
http://tipperlinne.com/p2bmod
Btw, P2B was time ago selling one of his modded boards for 2 Tuallies
Regards, SPAJKY ®
& visit my site @ http://www.spajky.vze.com
"Tualatin OC-ed / BX-Slot1 / inaudible setup!"
E-mail AntiSpam: remove ##
> with VP6
The P2B modification business is pretty slow these days, but my services
remain available and advice is free as always 🙂
P2B
