H Habib Karibi Reputable Nov 10, 2014 3 0 4,510 Nov 10, 2014 #1 my power supply doesn't have a 6pin connector for my graphics card, was wondering if this was safe to use
Solution Gam3r01 Nov 10, 2014 The dual 4pin to 6 would offer more stable power, the 7850 dosent draw much power. You should be fine.
Gam3r01 Titan Jan 12, 2013 25,414 973 115,440 Nov 10, 2014 #2 What card and PSU? They do work, but they are not recommended by any means. Upvote 0 Downvote
H Habib Karibi Reputable Nov 10, 2014 3 0 4,510 Nov 10, 2014 #3 The graphics card is Gigabyte Radeon HD 7850 http://www.gigabyte.com.au/products/product-page.aspx?pid=4155#ov i also have a 2 molex to 1 6pin adapter, should i use that instead? not really sure what the power supply is Upvote 0 Downvote
Gam3r01 Titan Jan 12, 2013 25,414 973 115,440 Nov 10, 2014 Solution #4 The dual 4pin to 6 would offer more stable power, the 7850 dosent draw much power. You should be fine. Upvote 0 Downvote Solution
H Habib Karibi Reputable Nov 10, 2014 3 0 4,510 Nov 10, 2014 #5 Thanks for the help Upvote 0 Downvote
