Build Advice $1,500-2,000 Gaming Build Help
Nov 26, 2022
I hope I’ve found the right place to request help. I read one of the stickied posts here so I will try to give all the details I can as requested.
As the title suggests, I am seeking a build within the $1,500-2,000 range. I aim to use it primarily for gaming but it will be used for business as well (nothing intensive, just spreadsheets). I will need an OS and a monitor, so that is included in the desired price range. I live in Georgia (that was mentioned as helpful information in the post). I mainly go for modern AAA titles but play a bit of about everything else (I assume that’s most people). I have built a PC once before but sold it after college. It’s easy to search for all the best parts independently, but when it comes to harmonizing everything into a desired price range I’m out of my element. I’m seeking the best I can afford of course. It’s not an urgent purchase either; I just want it within the next month.
Thanks!
Reactions: Why_Me
Why_Me
Champion
Intel's 13 gen locked cpu's along with the B760 boards are due for release Jan. 3rd and those will be a game changer for people doing builds with a similar budget as yours. Also keep in mind that DDR5 is dropping in price on an almost weekly bases.
https://wccftech.com/intel-b760-motherboards-13th-gen-non-k-cpus-to-launch-on-3rd-january-2023/
https://videocardz.com/newz/intel-to-launch-13th-gen-core-non-k-cpus-and-b760-motherboards-on-january-3rd-2023
This gives you an idea of what you're looking at build wise.
https://www.newegg.com/p/2AM-000Z-000A7
LIAN LI LANCOOL 216 X Mid Tower Computer Case $99.90
https://www.newegg.com/phanteks-amp-series-ph-p650g-us01-650w/p/N82E16817987009
Phanteks AMP 650W 80+ Gold Modular Power Supply $64.99
B760 DDR5 Motherboard $160 - $180 if I had to guess
Intel Core i5 13400F $200 - $250 if I had to guess
https://www.amazon.com/DeepCool-AK620-High-Performance-Dual-Tower-Dissipation/dp/B09CSXS3X4
DeepCool AK620 CPU Cooler $64.99
Expect this RAM to be significantly cheaper by this January.
https://www.newegg.com/g-skill-32gb-288-pin-ddr5-sdram/p/N82E16820374327
G.SKILL Ripjaws S5 Series DDR5 5200 32GB (2x16GB) CL36 $148.99
https://www.bhphotovideo.com/c/product/1614794-REG/pny_technologies_m280cs2130_2tb_rb_2tb_cs2130_nvme_m_2.html
PNY CS2130 2TB M.2 PCIe NVMe Gen 3 x4 SSD $124.99
https://www.newegg.com/msi-geforce-rtx-3060-ti-rtx-3060-ti-ventus-2x-8g-ocv1-lhr/p/N82E16814137673
MSI GeForce RTX 3060 Ti Ventus 2x OC 8GB Video Card $419.99
https://shopsoftwarekeys.com/shop/microsoft-windows-11-home-32-64-bit-usb-box-pack-1-license/
Microsoft Windows 11 Home 32/64-bit USB $72.99
https://www.amazon.com/LG-27GL650F-B-Ultragear-Compatible-Monitor/dp/B07R7636MH/
LG 27GL650F-B 27" Full HD Ultragear 144Hz IPS G-Sync Compatible Gaming Monitor $179.99
Total: $1400
https://www.tomshardware.com/reviews/deepcool-ak620-review
https://www.lg.com/us/monitors/lg-27gl650f-b-gaming-monitor
https://lian-li.com/product/lancool-216/
View: https://www.youtube.com/watch?v=5nZhqlO8-ek
