The forums will be offline from 9AM EST (6AM PST) 12/12 as we will be performing scheduled forum maintenance. We hope to be back online ASAP and thank you all for your patience.
So im planning on getting a Corsair H115i pro and the radiator has two 140mm fans on it. My Mobo has only one single cpu fan header. Would it be a good idea to buy a 1-2 fan splitter or does the h115i pro come with a fan splitter?
The fans are connected to the waterblock,from where one three pin will connect to the cpu fan header. They then can be controlled by the Corsair software by using the usb cable,again comes from the pump,to connect to an appropriate usb header on the motherboard.
