I need some advice! I want to add some more ram to my system but I cant decide if I should: add 1 gig of 800mhz cas4 for $81
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145040
(I currently have the 2gig version of this installed)
Or should I add 2 gigs of 675 cas4 for $89
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145015
(I figure I could OC this with a little extra voltage)
Should I worry about futureproofing and go with the higher mhz.? Would 4 gigs of ram actually show a difference vs. 3 gigs? Also I dont see myself pushing my E4300 much past 3ghz.
My current ram:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145034
Thank in advance!
My current ram:
Thank in advance!
