[SOLVED] 1 monitor blurry and not at full resolution
Jun 8, 2021
16
I bought 2 of the same monitors today and currently using them right now, they're both 60hz but should be able to output 1440p but the issue I'm having is that on 1 monitor it's fine and is at 2560 x 1440 but on the other one it's limited to 2048 x 1152 and it shows that the 2nd display is slightly smaller than the first. For the first monitor I have a DVI to HDMI cable connected to it and for the 2nd one it's connected through VGA, could that be the reason that this is happening? I should add that the card they're connected to is a GTX 650. Is it because of the VGA cable and would it be possible to get a DVI to Dual HDMI for the fix or something?
