[SOLVED] 1 Monitor Mount with 2 arms that are different sizes
DiarmaidB
5
Hi There,
My friend currently owns an MSI OPTIX MAG27C and he is planning to buy a Philips 278E9QJAB for a dual monitor setup.
He currently does not own a monitor mount for either, but he is planning on buying one.
He wants to buy a single mount with 2 arms, however, from what I could tell, the mount brackets for the two monitors will need to be different sizes (VESA Mount: 75mm x 75mm and 100mm x 100mm respectively).
Does anybody know if it is possible to get this or will he need to buy 2 separate mounts to make it work?
Thanks in advance
