1 Radiator work for CPU Water Cooler? Other one doesn't fit
MrOukus
Commendable
Jan 27, 2017
14
Hello so I'm building my computer and I did everything but 1 problem.... I have the nzxt kraken x62 with the ryzen 7 1700x and ASUS B350 Gaming STRIX Mobo but I can't fit the other radiator because the motherboard heat sink is in the way . Can I just use 1 radiator and leave 1 open please yes if I can, will it break my computer right away??? Will something bad happen ? What should I do? Use 1 which is what I'm planning on doing or do I really need 2?
Break the computer no, but with half of the cooler not having a fan on it you are going to kill its efficiency, you may as well get an air cooler as its not going to work very well.
Get a different case or find another place to mount the radiator so it can use both fans.
