Hello everyone,
I put my specs down at the bottom, so here goes. My PC idles around 108 degrees F. When surfing the net and watching HD movies I get around 113 degrees. When playing 90% of games I get up to mid 120s. When playing Diablo 3 or Star Wars the Old Republic (MMO) I get up to 131 degrees F.
I specify 131 because that is when games start to stutter and soon I get a Blue Screen of Death. I avoid this by using the latest Catalyst Control Center to turn my GPU (AMD 6870) fan up from 40% to 60-65% This usually takes me out of 131 degrees down to a playable 127. As for fans I have 3, one a part of the Aprevia Xplorer 2 mid tower case.
I would very much appreciate some tips on how to keep my PC cooler as well as an answer to why I get Blue Screened at such a temp.
Specifications (Cyberpower pre-built):
CASE: Apevia X-Plorer 2 Mid-Tower Case w/ Side-Panel Window and MultiMeter Display with 200mm UV Green LED Fan
CPU: AMD Phenom™II X6 1055T Six-Core CPU w/ HyperTransport Technology
FAN: XtremeGear Liquid Cooling System 120MM Radiator & Fan (Enhanced Cooling Performance + Extreme Silent at 20dBA)
HDD: 64 GB A-DATA S596 Turbo Series Gaming MLC Solid State Disk
HDD2: 1.5TB SATA-II 3.0Gb/s 32MB Cache 7200RPM HDD
MEMORY: 4GB (2GBx2) DDR3/1600MHz Dual Channel Memory Module (Kingston HyperX)
MOTHERBOARD: GigaByte GA-870A-UD3 AMD 870/SB850
POWERSUPPLY: 800 Watts - XtremeGear Gaming Power Supply - Quad SLI Ready
VIDEO: AMD Radeon HD 6870 1GB GDDR5 16X PCIe Video Card
Im guessing this might have something to do with the cheap cooling and/or cheap PSU. Even though its 800 watts it was the stock Cyberpower PSU a year ago as it doesn't say anything about being 80 Plus. Wouldn't be surprised if the specs were similar to what they have now :
• Model No: ATX-CB800W
• AC Input Voltage: 115/230V
• AC Input Frequency: 50~60Hz
• AC Input Current: 13A (RMS) for 115VAC Input
• Output: 6.5A (RMS) for 230VAC Input
I'm willing to upgrade anything. I really appreciate anyone who takes the time to check this out. Also my PC sits on top of a desk in a room with an avg 70 degree F ambient temp.
