Question 100% cpu and disk usage, need help!!!
Apr 22, 2020
24
I recently upgraded a lot of parts in my pc. These include the cpu, motherboard, and psu. I also got a new case as well. I’m using the same Hdd though. When I got my pc working, I’m getting 100% cpu usage briefly and then 100% disk usage for a while. I have tried almost everything I’ve seen online. Scanning for viruses, disabling sysmain and windows search, checking for the pci express bug, updating windows, updating drivers, and more. I have no idea what to do. I’m a student and I need to do my work but I can’t if my computer is practically unusable. Any help would be greatly appreciated. I’ll leave my pc specs below
intel Q77MK motherboard
I-5 3570
Gtx 1050
14 gb ram ddr3 1333 mhz
Evga 400w psu
My hdd is pretty old, I’m not sure of the exact name but it’s a seagate 500gb hdd that runs at sata 3gb/s
Apr 22, 2020
24
watch Task Manager and see which processes are causing the CPU\disk % spikes.
you can also check for an updated BIOS. if this is a motherboard hardware issue it may have been corrected with an updated version.
Nothing is really taking up much disk at all in the task manager, but it’s still at 100%
And intel discontinued bios updates for their motherboards in 2019, so I don’t think there’s much I can do about that.
where are you seeing the CPU & disk usage spikes, what monitoring application?
fresh os install?
I tried that last night, no results.
when you did a fresh OS install, did you delete all partitions and format the entire disk?
if yes;
just buy a cheap priced SSD and do a fresh OS install on that.
if the problem stops, than you know it was a malfunctioning disk. plus you have a better drive to continue on with.
Apr 22, 2020
24
if yes;
I’m seeing it at 100% on task manager, and no I didn’t delete all the partitions and format the entire disk, how do I do that?
if you are seeing 100% disk usage in Task manager with the "More Details" option enabled, than there should also be a process there in the "Processes" tab's list that is also showing a high MB/s.
you can either use a 3rd party disk management software
or when installing a fresh version of Windows from a disc or a USB flash drive, it will come to a section that asks where you want to install.
here you should be able to choose to delete partitions on the disk and format the entire drive.
Apr 22, 2020
24
Alright, thank you. And will doing this re-install wipe out all of my files of my computer?
Apr 22, 2020
24
yes.
you will have an option to "Keep my existing files" or something similar which you can select
or you can use a 3rd party backup software like Acronis True Image or something similar to backup your personal files.
Okay. I have most of my personal files backed up onto a flash drive. I guess I’ll just choose to wipe everything out, I feel that’ll be more effective.
Apr 22, 2020
24
if yes;
I just did a fresh install of windows 10, no results. I ran a check disk and checked for errors in my drive’s properties, no results. I guess the only thing I can try now is to buy a whole new drive, but I still don’t understand how it could work perfectly fine before I upgraded some hardware and now it’s doing this.
i would guess you have already tried different SATA cables and different SATA ports?
being an old drive, you never know. could just be a coincidence that it failed at the same time.
or could've been some kind of power fluctuation when powering up the new hardware for the first time, etc.
a lot of times disk usage spikes are due to malware running constantly. but if you successfully wiped the only drive installed and everything on it, that would now be impossible.
Apr 22, 2020
24
I tried a different sata port and that didn’t help, I’ll try a different sata cable if I have one. I guess I’ll pick up an ssd from Best Buy or something and see if that works. If that doesn’t work I’ll truly be stumped. I guess I’ll have no option but to take it into one of those overpriced half-scam computer tech places or just downgrade to windows 8 or something and see if that works seeing as this is a known problem with windows 10. I appreciate all of your help man, and if you think of anything else just let me know, and I’d greatly appreciate it.
