$1000 build help!
Keysas411
5
Parts NOT needed: A monitor, OS, Mouse, And a keyboard.
Optional Parts I would love to have: A Router adapter (so I don't have to use Ethernet), and some Very cheap speakers (until I can save up).
Major things ill be doing: HD Gaming, Watching Hd youtube videos, and Surfing with a million tabs open.
Time Frame: No time frame.
I might overclock But I will defiantly NOT combine 2 graphics card (forgot what thats called)
Here Are The Parts Im Interested In:
All Parts Are From Newegg.com
The Case - ZALMAN Z9 Plus Black Steel / Plastic ATX Mid Tower Computer Case
The Motherboard - GIGABYTE GA-Z68X-UD3P-B3 LGA 1155 Intel Z68 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
The Graphics Card - EVGA SuperClocked 01G-P3-1567-KR GeForce GTX 560 Ti (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
The Power Supply - Corsair Enthusiast Series TX650 V2 650W ATX12V v2.31/ EPS12V v2.92 80 PLUS BRONZE Certified Active PFC High Performance Power Supply
The Processor - Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
The RAM - G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL
The Hard drive - SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
The Dvd/Cd Reader - SONY Black SATA DVD-ROM Drive Model DDU1681S-0B - OEM
The Router Adapter - Premiertek PT-H10DN-1W USB 2.0 WiFi Adapter (Im Not Sure If This Will Work Good For Online Gaming!!)
[strike]Solid State Drive (Not sure if I need it) - Patriot Torqx TRB PT32GS25SSDR 2.5" 32GB SATA II Internal Solid State Drive (SSD) [/strike]
TOTAL - [strike]$1,052.90 [/strike] $982.91
SHIPPING - $10.75 (Covered. Dont include this in the budget!)
Once Again All Parts Are From Newegg.com!
I do Feel like I am missing something but I just cant find out what it could be.
I hope this plays minecraft well
r0aringdrag0n
First: Everything looks compatible
Second: I believe the best company to buy an SSD from is OCZ
Third: the double graphics card is called SLI for Nvidia or Crossfire for AMD
Fourth: It'll play minecraft on highest settings
fifth: the SSD isn't really going to help you UNLESS you want boot times that are faster (which imo is worthless, save the $90 to get ice cream while your computer loads)
sixth: You NEED TO OVERCLOCK your MoBo to use that RAM (it's running at 1600)
r0aringdrag0n
Go into the BIOs and go to Performance or something like that. Then you have 2 options To increase the clock rate or the multiplier. for example a 3.4GHz processor might be running at a clock rate of 100MHz, but have a multiplier of 34, therefore 34 x 100 = 3400MHz, which is equivalent to 3.4GHz. Increasing any of the 2 will increase your CPU performance and be deemed "overclocking"
WARNING: overclocking can decrease the life of your system and can potentially destroy your CPU.
This is a good video for Overclocking: http://www.youtube.com/watch?v=bpwcQH-AATE
You DO NOT want to get that motherboard if you do not plan on running dual vid cards!
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157230 $109.99 FREE SHIPPING
ASRock P67 PRO3 (B3) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207013 $69.99
XFX Core Edition PRO550W (P1-550S-XXB9) 550W ATX12V 2.2 & ESP12V 2.91 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Active PFC Power Supply
or....
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371047 $68.99
Antec High Current Gamer Series HCG-520 520W ATX12V v2.3 / EPS12V v2.91 80 PLUS BRONZE Certified Active PFC Power Supply
Now combo that card with the cpu to save $15...
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.662489 e: -$15.00 $454.98 $30.00 Mail-In Rebate Card Price After Mail-In Rebate(s): $424.98 FREE SHIPPING
EVGA SuperClocked 01G-P3-1563-AR GeForce GTX 560 Ti (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233082 $29.99 FREE SHIPPING
XIGMATEK Gaia SD1283 120mm Long Life Bearing CPU Cooler bracket included I7 i5 775 1155 AMD and dual fan push pull compatible
