~$1000 Build Review - How does it look?
danb_33
6
How does this newegg ~$1000 system look for gaming:
- CPU: AMD Phenom II X4 940
- MOBO: ASUS M4A79 Deluxe 790FX
- RAM: G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 1066 (PC2 8500)
- Vidcard: EVGA 512-P3-N871-AR GeForce 9800 GTX(G92) 512MB 256-bit GDDR3 PCI Express 2.0 x16
- HD: Western Digital Caviar Black 1TB 7200 RPM SATA 3.0Gb/s (WD1001FALS)
- Power supply: Rosewill RP600V2-S-SL-S 600W ATX12V v2.01 SLI
- OS: MS Windows Vista Home Premium
Thank you for your review.
--danb
MykC
480
Lose the 790FX board, it cost more for what you'll need. The FX boards are only recommended if you want to run 4850X2 or 4870X2 in quadfire.
Personally, I'd go with this RAM:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145184 Corsair DDR2 800 $45 - $20MIR Why pay more?
However, if you want something with better timings:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231209 G.Skill PI Black DDR2 800 $45
All in all, I don't recommend the price DDR2 1066 over DDR2 800.
The videocard you chose is nvidia on a crossfire platform. If you have no plans on running two GPUs down the road thats fine, but after you move from the 790FX to a 780GX then you can afford this upgrade.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102801 1GB 4870 $190
Motherboard solutions:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128384 Giga 790GX $90 (xfire) COMBO deal $50 saving with the 940BE chip on new egg.
Either of these PSU if you don't plan to crossfire:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341010 OCZ 600W $70 - $20MIR
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341022 OCZ 550W $80 - $20MIR
If you do plan to crossfire:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341011 PCP&C 750W Red $110 - $15MIR 4x6pin
Cpu cooling
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186020 Artic MX-2 Thermal Compound $7
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233003 Xigma $36 - $10MIR (AMD)
Case:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119137 CM 690 $80
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.165047
1. AMD HDZ940XCGIBOX:
2. GIGABYTE GA-MA790GP-UD4H
$288.89
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231166
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066
$53
Vista
$99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152102
SAMSUNG Spinpoint F1 HD103UJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb
[faster, quieter and cheaper than the WD]
$99.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC
$94.99
So far all that works out at $637 , which leaves $360 for a badass gfx card . Something that will chew the GTX 250 up and spit it out b4 breakfast .....
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102813
SAPPHIRE 100260SR Radeon HD 4850 X2 1GB 512-bit
$244.99
[ might as well be ATI since the board can accept another ATI card in crossfire ]
which means you have a $115 to buy a case if you need one , or more beer if you dont
xthekidx
Splendid
Dec 24, 2008
3,871
All of the above suggestions are good. Definitely lose the Rosewill PSU, I would only use it as a doorstop.
What size monitor will you be playing on? That has a large effect on the amount of GPU power you need to run your system.
danb_33
6
For monitor, going to use my 52in 1080p sony bravia tv.
Okay, great advice, thank you.
So here is where my head is at w/ new setup based on your reviews:
AMD Phenom II X4 940 BE
GIGABYTE GA-MA790GP-UD4H AM2+/AM2 AMD 790GX HDMI ATX
$288
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.161274
Saphire Radeon 4870 1GB
$195 (w/game incl: Stalkers)
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500)
$53
$99
OCZ Fatal1ty OCZ550FTY 550W ATX12V
$80 w/ $20MIR
XIGMATEK HDT-S1283 120mm Rifle CPU Cooler
$37 w/ $10MIR (free 15ft USB cable)
COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower
$80
http://www.newegg.com/Product/Product.aspx?Item=N82E16823126174
Logitech EX 110 Black USB + PS/2 Standard Cordless Desktop Keyboard & Mouse
$30
ARCTIC COOLING MX-2 Thermal Compound
$7
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136152
LG DVD/CD Burner
$25
Vista Premium
$99
Total w/ tax & shipping = $1100
How does this look? Quality system for the buck?
xthekidx
Splendid
Dec 24, 2008
3,871
Yeah it will be ok for that system you have listed, but I think I would spend more on the GPU if you are going to use 1080P resolution...but again this depends on the games you play, some are more demanding than others. Crysis will run slowly I think, as will Far Cry 2. I would go for a 4850x2 I think, or maybe get 2 4830's in xfire, they scale very well and will perform better than the 4870 1gb.
MykC
480
Depending on the settings your willing to live with, Far Cry 2 plays perfectly fine on high at 1080p on my 9800GT (min FPS 25 when action gets hot), so a 4870 is do much better even if you take the graphics to very high. With Crysis, it really didn't run well at all, medium settings with high physics was the best I could do. A 4870 will be fun as long as you can live without Very High and AA.
