Approximate Purchase Date: In the next two to three months
Budget Range: 1000-12000 Before Rebates
System Usage from Most to Least Important: Gaming, School, Videos
Parts Not Required: Keyboard, Mouse, Monitor, Speakers, OS
Preferred Website(s) for Parts: Newegg.com
Country of Origin: United States
Parts Preferences:I would like to use Intel CPU and Nvidia Graphics Card
Overclocking: Maybe
SLI or Crossfire: No (and not sure what this is but i think it doubling graphic card, if so no)
Monitor Resolution: 1366 x 768 or higher
Additional Comments: I would like it to be quiet and not have to worry about heating issues. Also I would like advice on the parts in using.
Case: Corsair Obsidian Series 650D (CC650DW-1) Black Steel structure with black brushed aluminum faceplate ATX Mid Tower Computer Case http://www.newegg.com/Product/Product.aspx?Item=N82E16811139006
Graphics Card: MSI N560GTX-Ti Hawk GeForce GTX 560 Ti (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card http://www.newegg.com/Product/Product.aspx?Item=N82E16814127578
Power Supply: CORSAIR Professional Series HX650 (CMPSU-650HX) 650W ATX12V v2.2 / EPS12V 2.91 SLI Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply http://www.newegg.com/Product/Product.aspx?Item=N82E16817139012
Ram: CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C9 http://www.newegg.com/Product/Product.aspx?Item=N82E16820233144
Heatsink: COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible Intel Core i5 & Intel Core i7 http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
Motherboard: ASUS SABERTOOTH P67 (REV 3.0) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard http://www.newegg.com/Product/Product.aspx?Item=N82E16813131702
CPU: Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) 4 x 256KB L2 Cache 6MB L3 Cache LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
Hard Drive: Seagate Barracuda ST31000524AS 1TB 7200 RPM 32MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive http://www.newegg.com/Product/Product.aspx?Item=N82E16822148697
CD Drive: LITE-ON DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model iHAS124-04 - OEM http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289
Overclocking: Maybe
