Question 10400 - 100W max TDP heatsink
PL2 power draw is only for a limited period of time, assuming the motherboard doesn't default PL2 time to infinity. So you don't need a heat sink to handle PL2, only PL1 since that's the steady state power draw.
However I still wouldn't put something less than say an Arctic Freezer 34 or a DeepCool A400 on it.
Reactions: Dj0gany
The 10400's PL2 is 134w, per Intel defaults, but your motherboard's presets may be customized to something else.
Put a decent cooler on the cpu, be it a Thermalright Assassin X or Deepcool AG620... or one of those Vetroo V5s.
Whatever this 100w cooler is, it probably isn't much better than the cpu boxed coolers.
The stock heatsink the max tdp is 65w?
You can always adjust the PL2 to be below the max performance of the cooler so that you will always have good (enough) temps on the CPU.
Whatever cooler you put on your CPU that's how high the max power draw of the CPU will be, if the cooler can only cool 100W then the CPU will only draw 100W ,if you don't adjust PL2 the CPU will run at 100C when you run heavy loads on it but that will not damage the CPU.
Reply from Intel:
"Thank you for your reply.
For the i5-10400F cpu the stock cooler is E97379-003 and the max tdp for this cooler is 65W, but it has been tested and it's enough for this processor. You can find below the article regarding this:
https://www.intel.com/content/www/us/en/support/articles/000058835/processors.html
Let us know if you have further issues or this answered your question. We are waiting for your answer and in case we won't hear from you, we will get back to you in 2 business days."
Yes, a 100w max tdp cooler is more than enough for this cpu and it will keep it much cooler.
