The intel combo is better if you want to game and do workloads that depends of faster single core speed and minute burst loads. If you want to get a CPU for moderate workloads, gaming, with great features and future-proof till 2-3 years you can go with the Ryzen Combo. Currently Iam using 3600XT paired with RTX 2060s from Galax and 2×8gb kit of ADATA XPG 3200Mhz. In my opinion I would like tell you to go with the Ryzen combo since AMD has better boost algorithm which makes the cores to run at higher clocks with better stability and longevity.
