1050ti i5 6600k running bf1, can't get above 30fps on low
Lima85
4
I have a gtx 1050ti with an i5 6600k cpu. I've seen the exact same set up I have run high and ultra settings in BF1 and get 60+ no problem. On low I can't even reach 30fps.
All drivers are updated, I've played with the in game settings and can't get it to be playable. Any guidance is appreciated!
Thanks
Need to grab a cable tomorrow at the store to connect my monitor to the 1050ti. At the moment it's connected to the Mobo via VGA. This is a fresh build, so I'm trying to fine tune it.
CPU and GPU temps are all normal, not even close to a concern.
Should I disable the on board video in order to be sure it's running on my GTX 1050ti?
according to the following;
Battlefield 1 Recommended Requirements
CPU: Intel Core i7 4790 / AMD FX 8350 Wraith
RAM: 16 GB
OS: 64-bit Windows 10 or later
Video Card: DirectX 11.0 Compatible video card (AMD Radeon RX 480 4GB / nVidia GeForce GTX 1060 3GB)
you do not meet the requirements for high FPS on low setting.
I guess I found the problem lol
Like I said it's a new build & im new to this. I was unaware plugging in to the mobo would be that big of a difference. I'll update later today once I get the proper cable. Thanks!
I appreciate all the help. Bought an adapter and plugged in to GPU, BF1 is now running over 70fps with an 80-90% CPU usage and my temps around 70-75C all on Ultra settings. Best part about it, I'm not even overclocked yet. Great help, thanks again!
