Question 1060 GPU is turning off and on 1 fan making annoying noise
It sounds like something is grinding on the fan. A cable or something similar. Or it's the bearing that has gone bad.
Check the fan of it has any obstruction using a flashlight. You can also remove the GPU from the system and check the fan by spinning it gently with your finger.
Dec 2, 2020
8
Thanks for the reply, now the GPU Fan has started wobbling and I have the gigabyte geforce gtx 1060 3gb OC windforce, how do I know what fans I can use to replace the broken one??
nofanneeded
Respectable
Sep 29, 2019
1,562
250
2,090
15
maybe this would fit , you need to take out the fan and read its serial number to know for sure
https://www.amazon.com/dp/B07NNS496V/ref=twister_B07BV9JXCH?_encoding=UTF8&psc=1
also you can check this site
Dec 2, 2020
8
Would I need the Fan A-b or just Fan a because my GPU has 2X fans.
Thanks for the reply btw.
Also I live in Australia if that changes anything
