FrostyBot :
king3pj :
Do you know the model number of the monitor? Most modern monitors support more than one kind of input. I would be surprised to see a new monitor that only supports VGA. If it supports HDMI or DisplayPort this is as simple as buying the right kind of cable. You can get decent quality cables for less than $10.
This is the monitor. https://www.amazon.com/Samsung-Simple-Monitor-Glossy-S22D300NY/dp/B00IEZGZY8/ref=sr_1_5?ie=UTF8&qid=1481567405&sr=8-5&keywords=samsung+sd300
According to the item description on Amazon that monitor does only support VGA. The store page also links to a newer (and cheaper) version of that monitor that supports VGA and HDMI as well as having a 24" screen instead of 21.5".
If you are still in the return window I would consider sending yours back for the newer, cheaper, and bigger model that won't require any adapters.
