Hi, I have an ASUS P5E Mobo, an e2140, an 8800GT, and 2 gigs of 1066 Ballistix memory. I put everything together yesterday and it's working great except I'm having trouble getting the RAM to run at the correct speed. First, I have the most up to date BIOS. CPU-Z showed my memory as PC2-6400. I have manually adjusted the speed and voltage of the RAM to get it up to 1066, but it still reads as 6400 in CPU-Z. Mainly I am wondering if I have got it working correctly and shouldn't worry about it being displayed wrong, or if this means that I will not get the most performance out of my memory. Thanks
Also set all other voltages to there lowest setting even if you not going to overclock, because most of the time the [AUTO] settings almost always set things to high than they need to be shortening your component life. Except for your CPU Vcore voltage set the stock value to stock volts printed on your processer box, mine says (for my E6600) 1.35 volt max unless your going to OC then don't set it past 1.45 volts. Good luck to you and if you have any questions please ask.
