1070ti Could I use 3 55inch or 60inch 4k tvs?
welge.jason
5
Hey guys finally upgraded to a 1070ti I love this fricking card. My question is could this handle 3 55 inch or 60 inch 4k tvs to run 3 monitors? I have a 8350 fx with 16 gigs of ddr3. My other question as well is my 8350fx is still bad ass. I run idle at 3 percent and no matter what I throw at this machine it still kicks butt. However I am a small video game designer using ue4. My compile times when packaging the game as a exe take quite awhile. So am wondering if a faster processor would make a difference, and if so what does everyone recommend? I did upgrade to a 860 evo Samsung SSD from my hyper x 120 gig.
Any advice???
and since your talking about 3 sadly your gtx 1070ti wont do that your best bet is to get a gtx 1080ti then you have a better chance for 3 4k tvs (my conclusion to this forum is you will have to get a better graphics card and also tell me the full specs of your pc
1070ti wont handle 3x 4k resolutions (no matter the screen size, that's irrelevant) neither will any single card out today. Would have to go sli to get decent frame rates of at least 60 but sli support isn't great. Might get away with 3x 1440p 27" monitors with 1070Ti at medium game settings at around 60fps, only a guess.
As said already that FX cpu is questionable.
Should say the reason why FX isnt very good is it's instructions per cycle isn't so great, there is more performance to be had from a 1070Ti with a stronger cpu. Seeing as you're enjoying the card's performance that's great, perhaps 8350 is enough for you.
