1080 FE Heat problems
killamaching190876
Commendable
Oct 10, 2017
68
Hey guys so I just got my 1080 FE, now I am playing rainbow six siege and evil within 2 and the temp gets to 82 max, now is this normal? Also i only have one CPU fan and one case fan, would you guys recommend getting more fans or a bigger case? Or do you think I will be fine without any additional cooling?
Cheers!
Still safe temps, however you might want to use MSI Afterburner to set a custom fan curve to keep temps low (<75 is ideal). You would benefit from 1 or two intake fans in the front as well.
FE cards run significantly hotter than open-air cards.
