1080p on a 32inch monitor?
Majdi_
4
hi everyone i found a 1080p 32inch curved monitor for 250$ should i go for it or is 32inch too big for 1080p i am using it for gaming btw
this is the monitor i am talking about C32F391
For $250, I would be looking for something with other features than just a larger panel. 32 inches seems a bit large for 1080p unless you are sitting relatively far from the screen, otherwise things might appear a bit pixelated.
Around that price range, it's possible to find some decent 1440p screens, though that might not be ideal unless you have a graphics card that can push decent frame rates at that resolution.
Or, go for a 1080p screen with a high refresh rate like 144Hz, which will allow you to view frame rates higher than 60fps, which can create smoother motion in fast-paced games. There are some curved VA panel screens (like that one) in the 24-27 inch range with a 144Hz refresh rate for a similar price.
The size of the monitor don't matter just the resolution.
You could have a 80 inch and a 24 inch if their both 1080p then the card would give the same performance .
For 32 inches to me that is to big for 1080p. Their people the use bigger at 1080p also though
I think curved screens really make more sense for an ultra-wide rather than a regular 16:9 widescreen.
On the other hand, I used a 27" 1920x1080 and was happy with it. My son's 34" 2560x1080 ultrawide is very nice, though some would argue that it's too low of a resolution for that screen size.
