1080P Output in Dell S2716DG Monitor???
Iver Hicarte
420
18
18,795
So I recently bought the dell s2716dg monitor, it's a 27 inch monitor with a maximum resolution of 1440p. So my question is.... for example if I play a game on this monitor in 1080p will the output be stretched with black bars on the side, stretch without black bars on the side, or will it perfectly fit with the monitor display??
The monitor: http://accessories.us.dell.com/sna/productdetail.aspx?c=us&cs=19&l=en&sku=210-AGJR
THANKS IN ADVANCE!
You can set that option in your graphics control panel. Sometimes the monitor will have it's own option as well that overrides. But they are the same aspect ratio so will have no black bars.
