1100 dollar gaming build NEED Help!
Pandaaz
39
I have been looking at this Motherboard: (ASRock Z87 Extreme4 ATX LGA1150 Motherboard ($129.99 @ Newegg) ) and seem to be stuck on the graphics card. I either want the EVGA GeForce GTX 770 4GB Dual w/ ACX Cooler (Part Number: 04G-P4-3773-KR) or the MSI N770 Lightning
Build:
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor ($219.99 @ Amazon) CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.98 @ Outlet PC) Motherboard: Asus Z87-A ATX LGA1150 Motherboard ($139.99 @ SuperBiiz) Memory: Team Xtreem Dark Series 8GB (2 x 4GB) DDR3-1600 Memory ($57.99 @ Newegg) Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($58.99 @ NCIX US) Video Card: MSI GeForce GTX 770 Lightning 2GB Video Card ($414.99 @ Newegg) Case: NZXT Phantom 530 Black ATX Full Tower Computer Case Includes 1 x 200mm Front, 1 x 140mm Rear 2 x USB 3.0 Fan Controller($129.99 @ Newegg) Power Supply: Corsair Enthusiast 750W 80 PLUS Certified ATX12V / EPS12V Power Supply ($69.99 @ Newegg) Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($14.98 @ Outlet PC) Total: $1130.89 This good?
AxlFone
Dignified
Other good mobo is gigabyte X-D3H or UD3H
And for video card Zotac AMP is really good choice.
Zotac gives you 2+3 year warranty and you can chance cooler if you like and this is will not avoid warranty.
http://www.zotacusa.com/warranty
http://www.zotacusa.com/register/product
Hope this helps :)
Btw. This is cheaper and better cooler than CM 212 EVO.
http://www.techpowerup.com/reviews/Raijintek/Aidos/
