D
Deleted member 362816
Guest
This build has given me more issues then I care to speak of, so I am sorry that I keep asking questions.
I have been away from intel since the 7700K maybe that is the issue.
Followed many overclock guides on YouTube, Reddit and Toms in regards to this specific CPU.
Simply put settings are as follows, 50 core multi on each of the 8 cores @ 1.350V Temps never exceed 60-65C in games showing 5GHZ. LLC Extreme, Multi Core Enhancement Disabled. Speed Step disabled.
When I run any program such as, Prime95,OCCT, Intel Burn Test, Cin R23, My temps are still under 75C but my cores drop to 4600 MHZ and 1.200V.
What is causing this to work correctly in all my games but when I run a extreme stress like any of the program listed above the core drops to the stock max boost voltage/multi?
I have all of the settings disabled that should be allow to lower the multi but yet it is still happening.
Willing to try anything at this point please let me know.
Specs
11700K
Z590i Aorus Ultra
RM850X
RTX 3070 FE
32GB 3200
Torrent Nano (2x140mm front 2x140mm bottom 1x120mm back)
Dark Rock Pro 4
Specs
11700K
Z590i Aorus Ultra
RM850X
RTX 3070 FE
32GB 3200
Dark Rock Pro 4
