Hey everyone,
I plan on buying the upcoming lian li O 11 air , for a total of 12 fans
Now, im just not sure how to approach the fan setup and control.
- The Mobo is the asus rog maximus X hero .
- I know that each fan header as a
maximum of 1 amp and that fans take more amps on startup.
- because the case is still not out im not sure how many 140 mm or 120 mm are supported.
- the fans I want are noctua NF F12 industrial ppc 3000 with Amperage of 0.3
And noctua NF A14 industrial ppc 3000 with amperage of 0.55
-in case the chassis supports more 140mm fans and i end up with 8 of those fans with 0.55 amps each . What would be the best solution to set up and control them? NZXT SENTRY 3( with 12 volts per channel but only 5 channels) Multiple fans hubs?
