~$1200 Gaming PC Build Help
Justin Leonard
4
Hey Everyone,
~edit~
I would like this system to be easily upgradeable in the future, as i plan to just build now and upgrade CPU/MB/GPU/Ram as needed
Student/Gamer here, I've been on a laptop for about 5 years now and am finally read to switch back to the desktop PC. I'll be building my own hopefully with some help from a friend, and clearly the internet. I've never done this before and can't really get my foot on solid ground with all the options.
I Play a lot of strategy games, Europa Universalis IV, Crusader Kings II, Civilization, etc. and a lot of RPG's, Mass Effect, Dragon Age, Elder Scrolls, etc.
I would like this computer to be able to handle games like these and their counterparts that will be coming out in the next few years.
If some parts can reasonably be bought used from sites like craigslist/amazon, I'm okay with that, (Particularly for the accessories).
If my requests below seem unreasonable for the price point, please let me know so i can make some adjustments/compromises.
Thanks in advance for the effort!
Approximate Purchase Date:
I would like to have all parts by the end of the year (Sooner is obviously better), That said if you guys know of any good times of year to buy parts like black friday, I am willing to extend my purchasing period, i would wait a little longer for a -great- deal.
Budget Range:
~1200 (Including monitor/mouse/keyboard)
System Usage from Most to Least Important:
Gaming, Data Processing (Excel/Stata/SPSS), Everything else
Parts Not Required:
I have nothing, Been on a laptop for 5 years and it's going to die soon 🙁
Preferred Website(s) for Parts:
Whatever has trusted quality.
Country:
US - California
Parts Preferences:
Intel CPU (i7 if possible)
Nvidia GPU
I live in southern California so the ambient temp is usually between 75-90 degrees Fahrenheit, so the case/cooling systems need to be able to compensate for being in a hot room.
I would also like to have a SSD + HDD, but i understand if that pushes the price point, I'll just stick with the HDD
Overclocking:
Not interested.
SLI or Crossfire:
Don't know the difference
Monitor Resolution:
1080p would be nice, i've never had anything over 1366/768, makes me wonder what i'm missing.
Additional Comments:
This is the current $1200 gaming build at pcpartpicker.com
http://pcpartpicker.com/guide/v7Xscf/1200-gaming-build
The are some changes I would make, but it gives you an idea.
Do you need a monitor, keyboard, mouse or Operating System. Do you plan to re-use the OS from the laptop?
I too have come off a 7 year old laptop. My philosophy is to build for about three good years, then strip everything salvageable (HDD, SSD?) and start again. In three years, you will need a new motherboard with a new chip socket, a new CPU, new memory (DDR4), and your GPU will be a couple of generations old.
I do need monitors/keyboard/mouse, but i'm thinking those might be best to get off of craigslist? I'm sure i have a Windows 8 floating around somewhere... for an OS until 10 comes out
Well.. Here's my attempt.
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor ($198.72 @ NCIX US)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($32.99 @ Mwave)
Motherboard: Gigabyte G1.SNIPER H6 ATX LGA1150 Motherboard ($90.00 @ Amazon)
Memory: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-1866 Memory ($73.80 @ Newegg)
Storage: Crucial M500 120GB 2.5" Solid State Drive ($68.99 @ NCIX US)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($54.99 @ Amazon)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE 3X Video Card ($349.99 @ Amazon)
Case: Corsair 200R ATX Mid Tower Case ($48.98 @ NCIX US)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply ($50.99 @ Amazon)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit) ($90.26 @ OutletPC)
Monitor: Acer H236HLbid 60Hz 23.0" Monitor ($129.99 @ Best Buy)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse ($29.99 @ Amazon)
Total: $1219.69
Generated by PCPartPicker 2014-10-07 20:40 EDT-0400
If you really want an I7, take out the CPU cooler and SSD. (go for 4790) But, if you're just gaming, stick with an I5.
As Tom has shown, the 'rules' for a $1000 Intel gaming machine (not overclocked) are fairly straight forward
i5 CPU. More money buys more speed (look a clock speed) 4690 is the fastest ATM.
CPU Cooler: Stock will work OK, but can be replaced later for better thermal or audio.
Motherboard: H97chipset (Could go Z97 if similar price for slightly better components)
RAM: 8GB, DDR3-1600 with lower CAS latency
SSD: 120 - 256GB: A must for systems in this range. For OS and applications. Massive speed improvement on boot and level-loading in games.
HDD: 1TB 7200rpm drive with 64GB of cache
GPU: Skipping to end
Case: Case with best heat management that you like (a place where some corners can be cut - $50 instead of $ 120)
PSU: Make this Teir 1 or Tier 2 for a build at this price.
Our list here :http://www.tomshardware.com/forum/id-1804779/power-supply-unit-tier-list.html
OS: Windows 8.1 - 64 bit (or Win 7 if you have a license you can transfer to save money)
GPU: The best you can afford. If you are running short of money at this time, I would suggest saving pennies, going without for a few months (my solution), or buying something temporarily really cheap used, then reselling it later. If the budget works, you could, instead leave out the SSD for later in order to get a very good GPU now.
This approach ensures that you build a good solid machine and do not cut the wrong corners (CPU, Motherboard, or Power supply)
The rest is to taste and budget.
The ACER monitor is a good fast inexpensive IPS monitor.
