120Hz 27" monitor NOT 3D
Outlaw1198
91
ok
so then as you can tell the title what i am looking for is not an overly expensive monitor but a good quality one that is 1920x1080 and the fastest response time posible (grey to grey) under 5 ms if posible as this monitor will be used for gaming so thanks and i have around £250 to use so that is my buget
For starters finding a 120 hz monitoer means your looking at 3D monitors because those are the only ones with that refresh rate.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236304
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236293
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009300
If you want to go with a lower refresh rate and get a nice 27" monitor for gaming then it becomes easier to find one.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824001551
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236101
I would go with this one.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236302
stanks i went with the one you recomended it seamed lie he best chicead i went with amazon uk and there is £70 off so thanks for your help and hava god new year
