120hz vga monitor
UniCorNXD
Commendable
Nov 14, 2016
33
So I found out that my old vga monitor actully has 120hz refresh rate. I want to know on what resolution will I need to play to achive 120hz, and if it would work with hdmi to vga adapter or should I use another one?
please help but you dont need to hurry because I dont have a PC yet, probally buying one used from amazon in next 2 weeks.
Thanks!
If the monitor utilizes 120hz via VGA; you'll just need to play around with the resolutions to figure out what one works best. For example; I had a 120hz monitor that only ran said refresh rate at a resolution close to 1600x1200.
It did for my buds BenQ XL27 monitor (1440p 144hz). He bought the monitor before he upgraded his GPU so he tried running a converter and it didn't work. He was able to squeeze out a 1080 resolution via VGA @ 100hz on a different monitor (ASUS VG24 I believe), however.
i have some old monitor, haven't tried with a converter.
But I will be still able to squeze out like 85hz or just try playing csgo on lower resolution, because monitor supports bunch of them.
