120mm Case Fan Recommendation?
faewww
Hey,
I am using realan case E-D3.It has a fan inside but I want to change a new one.
Can anyone recommend either:
a) A really good, really quiet 120mm case fan with a green LED, or
b) A standalone green LED that I can put in front of something like a Noctua fan that doesn't require an additional power plug.
Thanks!
Dec 15, 2018
i will recommand Corsair ML120 Pro LED ,It’s a best overall fan that you can buy . Now let me tell you why I love this model so much.First of all, the unique feature of these fans is that instead of a sleeve bearing or a ball bearing, they have a magnetic bearing. As a result, the fans are much quieter than its competitors which makes it
best case fans.
Apr 6, 2019
best case fans.
Hey, It's this site posted very Outdated things ?
Better Check https://ckab.com/best-120mm-case-fans/ They Update the List Monthly
