B Benjamin_77 Reputable Mar 26, 2017 57 1 4,535 Sep 15, 2017 #1 Looking for fairly cheap but effective 120mm case fans. Thanks!
Lutfij Titan Moderator Oct 7, 2009 58,874 6,079 178,440 Sep 15, 2017 #2 What is your budget and where would you like to purchase them from? What case would you like to populate them in? Upvote 1 Downvote
B Benjamin_77 Reputable Mar 26, 2017 57 1 4,535 Sep 15, 2017 #3 Preferably under £50 (want to get 4), and the case is a Corsair Carbide Spec 04, also preferably purchased from amazon. Upvote 0 Downvote
B Benjamin_77 Reputable Mar 26, 2017 57 1 4,535 Sep 15, 2017 #4 MERGED QUESTION Question from Benjamin_77 : "120mm case fans" Looking for four 120mm case fans for a Corsair Carbide Spec 04 case from amazon preferable under £50 thanks! Upvote 0 Downvote
Lutfij Titan Moderator Oct 7, 2009 58,874 6,079 178,440 Sep 15, 2017 #5 What about LED's on them? So for 4 fans 50 quid? How do you plan to connect them to your system? Do they need to be PWM? Please don't create multiple threads on the same topic. One thread with consistent answers. Moderator Lutfij Upvote 0 Downvote
B Benjamin_77 Reputable Mar 26, 2017 57 1 4,535 Sep 16, 2017 #6 Im not really too sure what your saying because i dont know massive amounts of detailed information. I guess they need to be the 4pin molex ones? Leds dont matter, but jf they come with them preferably red. Upvote 0 Downvote
