120mm fan help
halem111
177
hi, I have an antec 120mm fan
What i need is a way to power that fan from a plug because i am not going to be using it in the pc but to cool something else
Does anyone know of a way to power the fan via a plug
thanks
define something else? if you are going to plug it in to a wall outlet, a 12V power inverter will work. if in a car, hooking it up (via fuse) to any 12v source will work. if remote, find a battery tray to allow 12V and it will work.
