Hi all! My current build is sitting in pieces due to circumstances/issues, and to fix that I'm likely getting a new video card. I've decided that noise is a factor for me and supposedly the ACX style coolers are good for low noise. However, I also read that they need pretty good case airflow to work well. As such, I'm thinking that maybe now could be a good time to take the mis-matched hodgepodge of fans I have (most of which are pretty old) and get new ones that are nice and (hopefully) quiet.
The case I have is, to put it bluntly, a monster. It has 7 (SEVEN!) 120mm Fans on it and is an 18x18x18 inch Cube. I speak of the U2-UFO from Mountain Mods. There are 2 distinct sides to the case, the Mobo/Radiator side and the Drive Bay side.
The first side has a 3x120 Radiator on the front as intake, and a single 120 on (upper) back as exhaust.
The second side has a single 120 intake (lower), with 2 (upper) exhausts that also hold the HDDs for the system via fan mounts.
As you can see, that's a lot of fans to work with and noise can add up quick. Not to mention I wonder a little about the airflow in the case with all the mis-matched fans.
I know a few are Antec Tri-Cools, but looking up those specs on RPM/CFM/DB it's like holy cow they SUCK. I'm currently considering some Scythe Gentle Typhoons, as even though they are a bit pricey, the performance seems to be a ton better. I think I keep the Tri-Cools on low, which means they are moving like 40CFM each @ 25db. The Scythes can do MORE than that at 9 db! Or for roughly same noise (and I really think main noise in my case in video card) 85 or almost 100 (if I'm running on medium instead of low).
One has to hope that would vastly up air movement, which would be good for everything in the case. Especially since by going with water you lose some of that airflow from the CPU cooler.
So if anyone has any suggestions on some good, quiet, fans; a suggestion on mounting/speeds (like place a higher CFM/RPM on drive bay upper to try to pull air from bottom of case); or whatever I'd really appreciate it.
