M Mushroomboy28 Reputable Jun 20, 2014 16 0 4,510 Jan 21, 2016 #1 any ideas? im looking to do moderate OCing, maybe full turbo boost on it budget is around 80-90$
Solution Karadjgne Jan 22, 2016 The H55/60 run about 180-200w TDP. The stock 83xx run 125w. You've got room for some OC, albeit not much, but full turbo isn't a problem CPU Cooler: Corsair H80i GT 70.7 CFM Liquid CPU Cooler ($87.99 @ Amazon)
bgunner Judicious Feb 13, 2009 5,152 24 32,515 Jan 21, 2016 #2 Corsair H80 or H80i no less. The AMD Octacore CPU's produce a lot of heat so get a good one and save some money in purchasing a different on after. THe H50's and H60's will not be enough for that CPU. Upvote 0 Downvote
Karadjgne Titan Ambassador Dec 26, 2012 30,756 4,570 142,790 Jan 22, 2016 Solution #3 The H55/60 run about 180-200w TDP. The stock 83xx run 125w. You've got room for some OC, albeit not much, but full turbo isn't a problem CPU Cooler: Corsair H80i GT 70.7 CFM Liquid CPU Cooler ($87.99 @ Amazon) Upvote 0 Downvote Solution
