I would check the power supply, make sure the CPU and power supply fans are spinning up.
maybe swap out the power supply. if your GPU is overclocked and you have a marginal power supply unit, you might underclock the GPU to reduce the power pulled from the motherboard via the PCI/e slot.
Be sure to check all the power supply connections to the GPU and make sure they are providing power.
IE check any supplemental power connection from the GPU to the PSU.
sometimes if you turn off your browser graphic hardware acceleration and it actually helps, then the supplemental power connection might not be connected(if you have a gpu that has these connectors).
minidump shows a error writing to cache RAM inside the CPU.
on processor 2 cache bank 1.
cpu was running for 3 hours.
I did not see any GPU or CPU overclocking drivers.
generally a error like this would be caused by overheating of a CPU or a fluctuation in the power to the CPU.
This can happen if the power to the motherboard fluctuates. (check or swap out the power supply) I am thinking of the case of a GPU using too much power and causing a brownout to the motherboard. Them motherboard should reset the CPU in this case but I have seen some systems generate a 0x124 bugcheck.
Sometimes with certain specialize drivers you might generate this error as a side effect of a problem.
you might consider removing:
HUAWEI Mobile Connect - Bus Enumerate Device
\SystemRoot\System32\drivers\ew_jubusenum.sys Sun Aug 19 17:55:56 2012
update
\SystemRoot\SysWow64\drivers\AsIO.sys Wed Aug 22 02:54:47 2012
I would remove: the razer overlay driver (at least while testing)
C:\Windows\system32\drivers\rzpmgrk.sys Thu Jun 11 19:57:21 2015
Vuuts :
Still getting blue screens :/ I havent got bsod:s when on desktop. Only when gaming. What should I try next?
