128-bit 9800 Pro from Overclockers.co.uk?
Probe
8
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
I have emailed OC and Connect3D this morning but have not had a reply -
so...
I just got a Connect3D 9800 Pro from www.overclockers.co.uk I had heard of
the Sapphire 9800 Pro fiasco regarding the 128-bit memory bandwidth cards
sold as 256-bit and so was aware of the possibility. Overclockers made no
mention of anything but a full 256-bit 9800 Pro card. However, when the card
arrived this morning, I noticed a white sticker on the back of the box
saying 'Radeon 9800 Pro with 128MB 128bit DDR DRAM'. Surely that should read
'128MB *256-bit* DDR DRAM' to be a 256-bit 9800 Pro? The box blurb states a
256-bit memory interface.
Does a 256bit memory interface require 256-bit DDR DRAM or does the 128-bit
DDR mean 256-bit (i.e. double)?
TIA
"Probe" <probeit@yahoo.com> wrote in message
news:k8WBc.18993$NK4.3263108@stones.force9.net...
> so...
card
read
a
128-bit
> TIA
download everest from here
www.lavalys.com
Under display/gpu it will show you the bus width which should be 128bit.
Les
AMD64 3200+
2x512 MB corsair platinum 3500
Gigabyte GA-K8VNXP
Herc 9700 Pro - VGA Silencer 3
SB Audigy
The memory on this Connect3D 9800 'Pro' is Hynix and has a part number
HY5DU283222A. Looking on the Hynix site indicates that this is 128-bit
memory and not 256-bit. So even if the memory interface is 256-bit the
memory is not. Somebody surely must know something about the relationship
between memory bit-depth and memory bit-capacity....
> so...
card
read
a
128-bit
> TIA
Well, they don't make any memory that is literally 128-bits wide AFAIK (for one
thing that would require more than 128 pins/leads). That's why there's 4 Hynix
memory chips, I'm guessing each one outputs 64-bits (at least on my 9800 Pro
256-bit, 256MB). Maybe they've got 64-bit and 32-bit memory parts? Do they
still interleave memory access on video cards anymore?
-Bill (remove "botizer" to reply via email)
interface.
128-bit
Definitive answer.....use AIDA32 or download Everest (which is same thing)
and check under GPU properties. If it says 128bit....that's what it is.
> so...
> TIA
Damn, I never noticed that. I bought the exact same one 2 weeks ago and
it says the same. Rivatuner says 256-bit so I never thought it being one
of the crippled ones, but it might just get information from
predetermined things, i.e R350 = 256bit. I'm downloading the EVEREST
thing now, I'll say when it's done :-/
Please post the reply here if you get one, I'm now annoyed and intrigued.
Pip wrote:
>> so...
>> heard of
>> the card
>> should read
>> states a
>> 128-bit
>> TIA
Hmmm, that also says my mem bus width is 256 bit. So, anyone.. Is it or
isn't it? Is this program 100% accurate?
I've never known it to be wrong.
Like you I suspect the info from these programs since they could assume
256-bit - for instance, I am told that you can only tell an R350 from an
R360 GPU by removing the heatsink; yet Everest says it is an R350 GPU.
However, if you use Everest after overclocking the card a little with say
ATiTools, the figures do change - so it is gathering its own information to
some extent. Looking at these speed figures against other users' figures, it
does seem to be a 256-bit card. The company Connect3D replied to my email
saying that some of the boxes were mislabelled.
"Pip" <???@ntlworld.com> wrote in message
news:NP3Cc.1815$I43.1768@newsfe6-win...
> Pip wrote:
> >> so...
> >> heard of
cards
no
> >> the card
> >> should read
> >> states a
> >> 128-bit
> >> TIA
intrigued.
A good way to tell if the card is 128-bit or 256-bit is by the arrangement
of the RAM chips:
If the chips are in a single line above the processor, it's 128-bit.
If the chips are around the processor in an "L" shape, it's 256-bit.
If the chips are *not* BGA, it's 128-bit.
"War is the continuation of politics by other means.
It can therefore be said that politics is war without
bloodshed while war is politics with bloodshed."
> so...
card
read
a
128-bit
> TIA
here is a way to find out . Download 3dmark 2001 on futuremak site. Do the
single fillrate and Multitexture Fillrate
Should be 1400 for single or higher Multitexture 2400 and higher . If u get
that you have 256bit . If u get half that score have a 128bit.
news:U4hCc.19886$NK4.3361428@stones.force9.net...
to
it
> > Pip wrote:
reply -
> > >> so...
> > >> heard of
> cards
made
> no
> > >> the card
box
> > >> should read
> > >> states a
> > >> 128-bit
> > >> TIA
and
one
> intrigued.
