Hi
New build I’m doing for a family member. Bought the silverstone ps15 rgb case (wish I hadn’t now) and b450m mortar max. Checked on msi site that they were compatible, which it says they are.
Problem is when the RGB fan header is connected to the MB 5050 RGB header, the fans run at 100%.
I’ve tried amending the Bios and using the msi software. Nothing I do will change the speeds. However when I unhook the RGB, normal speed control resumes.
I’ve googled everything I can think of, I’ve emailed silverstone, downloaded the manual and watched numerous reviews of this case. Closest information I got was one mention in an Amazon review, which started off with the reviewer having a similar type problem and ended with him burning out the MB 😱
Help me TomsHardware forum, your my only hope!
